Originally posted by: dtyn
Centrino technology is cool![]()
Originally posted by: lilcam
ok ... so go with either centrino or builtin wifi. some models have the G and others have the B.
Now most of these lappys dont come with a floppy drive!!! damn, i need to dual boot, so if i screw something up under
linux, i would need to do a fdisk /mbr.
any other ways around this issue? i wouldn't even dare to use a floppy, but i would need it for the issue above. not sure how external usb floppies are.
Originally posted by: kermalou
what is the diff. between centrino and pentium m?
Originally posted by: Kevin
You might be able to get a seperate minipci card cheaper. However, if you get a Centrino it has to come with it.
You can boot from a USB floppy, there is usually a special method...
there is no guarantee that a laptop will have the proper minipci slot allowing for a wireless adapter. type 3 or was that C, is what is required. in my laptop, i know i have a type 2\b. i keep forgetting if they use letters or numbers for minipci types. and there is no guarantee that an internal antenna is there or accessible or usable.
