Is there some reason USB ports that are built into the motherboard don't work but others do? Is there possibly any bios settings that would cause this or some drivers that need to be installed or are they just brokened?
yes there is. what mobo do you have? try going to the peripherals section and see if USB is enabled. in my mobo, i didn't need to enable anything. i just connected the hub in the case and it worked.
