Built-In Bread Basket Door Replacement
Status
Not open for further replies.
MotionMan
17,124
12
In our kitchen, we have a built-in bread basket with a roll-up door like shown in these pictures:
I need to replace the door. I cannot find them at any B&M stores or online. My Google-Fu is failing me.
Any help would be appreciated.
MotionMan
Nov 26, 2005
15,190
401
Sorry I can't help but my opinion is the one on the left is much nicer than the one on the right. The one on the right looks cheap.. infact most things around it also look cheap :pukes:
MotionMan
17,124
12
I am just looking for a replacement for the one I had and the cleaning girls broke. :(
MotionMan
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Your Google-Fu is failing you because they aren't "bread baskets." Try kitchen appliance garage.
MotionMan
17,124
12
I actually call it the "kitchen garage", though others all seemed to refer to it at a "bread basket," and that is what I used to find the pictures.
I will try "appliance garage".
Thanks.
MotionMan
stinkynathan
497
Actually....the technical name for that thing is a "tambour door." Looks like you can get them from Rockler. We probably get ours from HDL, but I'm not sure if they do direct-to-public sales.
Is the track broken? I've had to install these before on-site....not so much fun...and I knew what I was doing.
<-Works in engineering/IT for a design-build, custom cabinet shop.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Thanks.
MotionMan
Here's a source I found but, you can make your own door fairly easily. You buy molding, either flat or round to match your existing door and cut them to length needed. You then glue them side by side on a piece of material (canvas works well). Allow to dry and stain or finish as desired. You then feed the completed door into the track and ad any hardware that you removed from the old door.
MotionMan
17,124
12
The track is fine. The actual door needs replacing. They broke many of the slats (or whatever they are called).
MotionMan
MotionMan
17,124
12
LOL. That is pretty much what we have (painted white).
Yeah, that is basically what it looks like. I would screw it up. :(
MotionMan
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
MotionMan
Well it's up to you but, I think the cost to replace the door is pretty crazy. Doing it yourself isn't rocket science or even torte reform. :D
If it were up to me, I'd tear out the appliance garages entirely. They just suck up useable counter space and, what is their function anyway? To make a kitchen look less like a kitchen?
highland145
43,973
6,337
This.
MotionMan
So. Do it twice. That's the norm for me.....at least. Man card, go for it.:p And it's a good excuse to buy more tools.
Pics of cleaning girls.......
Status
