jspeicher
How do you guys go about building your system -
Do you Install mobo/CPU/cooler and then power up first boot and then install HD and optical drives??
Or do you install everything at once and then load first boot? Including case fans, etc.?
Should I take it step by step and make sure everything is fine and then go back and add components and repeat , etc..
