Building New Water Cooled System With X2 3800, Need Suggestions.
CoBRaXT
1,241
I'm planning to upgrade my current air cooled Athlon 64 3000+ with an X2 3800. I'm thinking of cooling that as well as a Nvidia 6800 with water.
I looked around a bit and saw that I could either buy individual kits (brackets, waterblocks, etc) to put it a case or I could just buy a case (Koolance or the like) that has a water system built in. I'm going to need a new case anyway, so I was thinking the latter might be a better choice but I'm not an expert so I don't really know.
Should I just get a decent case and then add on parts (if so, which kit(s) do you guys recommend?) or just buy a case with it all ready to go?
And one last quesiton, I'll be running the X2 3800, a water cooling system, 6800, 2 Hard Drives, 2 Optical Drives, and 1GB ram.
I currently am running on a 450w Coolmax PSU (+3.3V: 30A, +5V: 45A, +12V: 22A). Do you think that would hold up with the new chip, etc? If not, what PSU's would you recommend for this setup?
Thanks for your help.
David
Edit: Budget is around $400-$500 for the case, water cooling, and PSU.
LxMxFxD3
257
sounds cool. YOUR PSU should be fine. I have an x2 3800 with way more stuff in my case and the only diff in our ps is my +12v is 26A I believe. GL
NotquiteanooB
362
Check out Corsair Cool Kit or Swiftech. Corsair is a bit less expensive, but basically a clone of the Swiftech. The Corsair Cool kits I installed were easy to install and do a great job cooling OC'd P4 CPU's, and my Barton CPU's.
