- Oct 9, 1999
- 15,216
- 3
- 81
The new system I am building is a AMD 1.4 Ghz proc. I am putting a new 20GB Maxtor hdd as my primary hard drive. This one is ATA 100, and my backup drive 30gb western digiral 5400 drive is also ATA100 I am going to put in my DVD rom and CDRW in this system (though I am not sure of teh CDRW - its a 2x Burner but it is useful in copying those occasional hard cd's).
Question is, how do I set the channels up so I dont get a slow down. If I mix ATA100, and ATA33, will it slow down that channel to ATA 33 speeds even if you use ATA 100 cables?
I am thinking possibly the old setting of
20Gb / DVD
30 GB / CDRW
will that work or should i make it
20 GB / 30 GB
DVD / CDRW
Which will be idea for speed. Either way dvd ripping and MP3 compression is optimisd as its on seperate channels ( I use the DVD for ripping). The second option looks tempting to me. should I go that way?
thanks
TGG
20Gb / DVD
30 GB / CDRW
20 GB / 30 GB
DVD / CDRW
thanks
TGG
