Building my system help...
jedisponge
75
Hey guys, I'm extremely distraught right now!
I recently ordered parts from newegg and a p5w dh from two places before finally getting a good one. I've put the system together and now its going kaput.
The first motherboard wasn't taking any power from the power supply. The light on the bottom corner didn't light up. After returning it and getting a new one from zip zoom fly (i got a 1305 bios rev from there if anyone's interested) and it took power! I was extremely happy, as I had to wait 10 days for my previous motherboard to get here. All this time and effort again, is causing me extreme mental anguish.
Anyway on to the problem now, I installed everything and I plugged the power in, and the system starts up by itself without me pressing the power. Everything's spinning, then stops in about 5 seconds. And its continuing to do this over and over again when I unplug the power and replug. I took the system to Best Buys and a Geek Squad dude looked at it, moved the memory in, out and about. He diagnosed the problem with bad memory, as when he left one stick in the power stayed on.
Now the problem is that he left it on for only a few seconds and turned the system off. Immensely relieved that I finally found the problem, I returned to my dorm and i tested it to make sure. I'm moving the sticks in and out and of course it continues to power off after a few seconds.
Now my question is... is it really a memory problem? Or could it be something else? Could it be a power supply problem? My power supply is a Rosewill 600watt SLI ready unit. Any help will be GREATLY appreciated. I requested an RMA from newegg, and before I send it I want to make sure if it really is a ram problem.
Bobthelost
4,360
Did you check the power switch? If there's a short in it or the reset button that could cause interesting effects. No other failure i know of should result in spontaneous boot/reboots.
PS. Rosewill is a really crap brand.
