I know these types of posts are popping up like wildfire lately and can be quite annoying, but this is my first go around putting together a rig (and possibly overclocking), so I'd really like to have some information in one place.
This is what I plan on putting together: (CURRENT EDITED SYSTEM)
MEMORY UNDECIDED AT THIS TIME
AMD 64 3000+ Venice - $146
EPoX EP-9NPA+Ultra ATX AMD Motherboard - Retail - $109.99
Enermax Noisetaker EG495AX-VE SFMA 2.0 (PFC) ATX 12V 2.0 485W Power Supply - $95
ATI (Connect3D) Radeon X800 XL 256MB DDR/PCI-E/TV-Out/VGA/DVI - $249
Thermaltake SOPRANO VB1000BWS - $80.49
SAMSUNG 997DF-T/T 19" CRT Monitor - $199.99
I probably will not overclock this beast immediately following assembly, but I plan to eventually. I am a total newbie at that process too and wouldn't know where to begin. I just want to make sure everything I pick up is compatible and OC friendly for now.
1) My goal is to get this system to match the performance of a 3700+ with stock parts and cooling. Is that moderate overclocking or would that be overreaching? Should I instead opt for the 3200+?
2) Is that motherboard a good bet for overclocking? Should I spend the extra money on a DFI board? What other alternatives are there?
3) How is the powersupply? Is OCZ reliable in that regard? What is the difference between a Modstream and Powerstream? It seems that PSU is priced pretty low.
4) Is the ram adequate for my goal of reaching a 3700+? Are there any similarly priced TCCD alternatives or is that quite a bit more? Will ValueRam with a Divider be enough?
NON OC misc questions
5) Is that CRT one of the best bangs for the buck I am going to be able to find? It seems difficult to find CRT monitor information these days. I do not think I am ready for the world of LCD.
6) I don't plan on buying a Harddrive right away, but what is the difference between a SATA drive with 16mb Cache and an SATA II drive? Which would provide better performance for large transfer of files and which for gaming? I am sure the difference is very negligible but I am just curious.
