1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
I need a PC able to handle multitasking. I run Firefox with 10-20 tabs which is a killer. I also run iTunes, MSN, torrent and poker clients. Very little gaming if any at all. I'd like it to be quiet, at least when not being used.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread 7-8k NOK, 1400-1600 USD.
3. What country YOU will be buying YOUR parts from.
Norway.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Intel > AMD, nVidia > ATi, Corsair PSU <3
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
None.
6. IF YOU have searched and/or read similar threads.
No.
7. IF YOU plan on overclocking or run the system at default speeds.
No. Default is fine.
8. WHEN do you plan to build it?
Next 1-4 weeks.
Case: Antec P182, Midi, ATX
PSU: Corsair 450W
MB: Asus P5Q Pro, P45, 775
CPU: Intel Core2Quad Q6600 2,4 ghz
CPU cooler: Zalman cnps9500led ultra quiet
GPU: Asus GF 8800gt 512mb gddr3, PCI-Ex 2.0, EN8800GT/G/HTDP/512M
RAM: Corsair Twin2x 6400c4dhx, 4096mb (2x 2gb)
HDD1 (OS+apps): WD raptor 74gb 10k rpm
HDD2 (stuff): WD caviar se16 500gb sata2 7200 rpm
Optical reader/writer: Samsung DVD recorder sh-s182d
WLAN: D-link AirPlus G 54 Mbps
So what do you think? This is the 2nd list after making some improvements from the first. Will the parts fit to eachother? How about space in the case? Both for the parts and my hands during assembly.
Norway.
None.
No.
Next 1-4 weeks.
PSU: Corsair 450W
