Building My First PC
blakewalla
Hey, trying to build my first PC. I want to make sure that I put together a list of parts that will work together correctly. I'm not gonna lie i read to FAQ's on how to build a computer and am now before you a novice. I plead for your help and consideration.
My most demanding programs will probably be Autocad Civil3D 2007 and Final Fantasy XI online. And maybe COD4 with all the settings turned down XD.
GIGABYTE GA-MA78GM-S2H AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard
AMD Athlon 64 X2 4800+ Brisbane 2.5GHz 2 x 512KB L2 Cache Socket AM2 65W Dual-Core Processor
EVGA 512-P2-N757-TR GeForce 8600 GT 512MB 128-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 20X DVD±R DVD Burner
TRICOD 9003 Black / Silver SECC Steel ATX Mid Tower Computer Case 500W Power Supply
If your wondering the total on this machine only comes out to be 444.93 so it is a bit thrifty but as far as i can tell this is what i need.
Thanks for your time reading.
Blake
RadiclDreamer
8,622
40
I personally dont see any issues other than the AMD cpu and the power supply. AMD used to be the best out there, but recently intel has been stomping them all over the place. The best performance for your money is going to be a C2D but if you want AMD go for it.
I would also dump the no name power supply for an antec or enermax
zelx
Its a nice basic machine. do you have a OS? i would wait a few days for better deals. i saw an 8800gs and cod4 for like $80 2 weeks ago.
blakewalla
Yeah for my OS i will be going with windows XP.
I added to this topic further in "General Hardware" I posted this here originally and realized it was better suited for the other thread.
Chosonman
1,136
The case looks like a cheap piece of junk. I'd go with the CoolerMaster Centurion for $49 shipped if newegg still has free shipping. Otherwise microcenter has is for $49 if you're lucky to have one close by.
I'd recommend spending the money to get a nice case. In the end that's the only thing you're really going to keep using after you upgrade.
