Building my first PC - will this case/PSU work?
Kipa
Thanks for checkin out my question. Below is the box I'm about to order (my first build). My question is I'm having a hard time determining whether the case I'm considering and the related PSU is adequate. I probably won't overclock (at least initially until I get more educated on the subject), but might want to in the future. Next question is how many fans to use? The case comes with 2 and the PSU has 2, but the case has room for more. All of the products below I found at newegg.com, btw. The box will mainly be used for heavy gaming. Please give me a little advice about the case/PSU. Also, I'd love any comments about the rest of the box as well (compatability issues or anything that might work better). Thanks in advance for your advice.
ANTEC PERFORMANCE PLUS Model# PLUS660AMG (METALIC GRAY) w/ ANTEC ATX12V TRUEPOWER 330W P4 READY POWER SUPPLY - RETAIL
ASUS P4PE Motherboard for Intel P4 478 Retail w/ Intel Hyper-Threading Technology, SATA, Gigabit LAN, Firewire IEEE1394
GAINWARD/CARDEXPERT GeForce 4 Ti 4200, 4ns, 128MB DDR, Power Pack Golden Sample
Intel Pentium 4 2.4BGHz 512K 533MHz CPU Northwood P478 Processor Retail Box
CORSAIR MEMORY XMS Extreme Memory Speed Series 512MB 32MX8 PC-2700C2PT With Platinum - Silver Heat Spreader OEM
SILVERSONY 1.44MB 3.5 INCH INTERNAL FDD DRIVE - OEM
WD WESTERN DIGITAL "SPECIAL EDITION" 80GB 7200RPM EIDE HARD DRIVE MODEL # WD800JB - OEM, DRIVE ONLY
I will also be throwing in my 52x HP CD-Rom and 8/4/32 HP CDRW from my old box for now. Initially I will use the on-board sound, but may add a sound card (SB Audigy) depending on the performance of the on-board audio.
Looks like a good setup so far. Case is very solid and will handle anything you throw at it. Power supply is plenty big too.
Standard Fan(s): 1 X 80mm (rear)
Optional Fan(s): 2 X 80mm (front)
Run fans in all 3 locations with air intake in the front flowing through and out the back. I believe there is a fan on the side panel also.
Seems fine with an excellent case and good PSU. Also, I would considering populating all the fan openings with low speed fans if there are extra opening.
Don't those cases have 2 fans in the rear? II thought Antecs were like the cheiftec, or is this one different? 😕
the antec 6xx series has only 1 rear fan. 8xx and up all have 2 rear fans standard.
deadseasquirrel
