I have lots of old hardware laying around and decided to do something with it. A quick perusal of Newegg and a few credit card numbers later, I have ordered an Nmediapc 6000S to match my HK receiver, an Asus OEM Blu-ray drive, a Cideco handheld keyboard/airmouse, a Buffalo Wireless NIC, a gaggle of extra fans and cables, and a Corsair 430 PSU to fuel everything.
What I already have-
C2D 6420 (formerly OC to 3.6, ran 3.4 as daily driver)
Freezer7 Pro
Giga 965 DS3
4X1GB Ram
8800gts 640
320GB HDD
250GB HDD
Yate Loon 120mm fans
My current HT system-
Samsung 46L630
DirecTV HD DVR
Sony PS3
Harman Kardon AVR 745
2X Infinity Beta 50 Towers
1X Infinity Beta C360 Center
2X Infinity Custom ERS-210 II surrounds
Behringer EP2500 w/fan-mod
2X Infinity Kappa Perfect VQ 12s in custom cabinets tuned at 17hz
2X Aura Pro Bass Shakers mounted to frame of couch w/100watt plate amp
I have no idea really what I want to do with this thing, but I know I want one, and I know I have enough parts laying around to make it happen. I will likely try Skyrim on my big screen and perhaps the occasional sports stream, although I cringe at the possible resolution. Maybe Netflix, but I can do that on my PS3 as well. I ordered a blu-ray drive just to have the capability, but will need some sort of software to play movies and perhaps back-up my blu-ray collection onto hard drive. I have no doubt I can come up with things to use it for, or perhaps it will be a useless project that entertains me for a week or so and then just looks cool on a shelf, regardless I have parts on the way and it is happening. I just need advice on what to do with it when it does.
Both of my HDMI inputs on the AVR are used by the DVR and PS3, so I will need to go directly from the HTPC into the TV. I ordered a DVI cable to do this, but now I need to decide the best way to get the sound into my AVR. Do I need a separate sound card or is the built in enough? What sort of Codecs do I need to play blu-ray movies on this OEM drive? What other software is recommended for an HTPC? I looked for a builders guide and found a guy that wanted $20 for his guide, but I am a much bigger fan of free. Any tips, hints, or comments before I start turning screws and connecting wires later this evening??
Freezer7 Pro
Giga 965 DS3
4X1GB Ram
8800gts 640
320GB HDD
250GB HDD
Samsung 46L630
DirecTV HD DVR
Sony PS3
