I have read mechBgon's guide a couple times. I am sure it will help me a lot but I have a few questions still.
Lets see here is what I am working with:
Thrmaltake Tsunami VA3000 case with 400w Thermaltake Powersupply
Epox Nforce3 MoBo
AMD 64 3200+
WD 74g 10k Raptor
DDRAM 1 gig Consair value pack
ATI Radeon 9800 pro 256 bit 256 memory
Going to go pick up a floppy drive at Best Buy Thursday (anything I should avoid?)
Sony CDRW/DVD combo drive
MS XP home
I recieved my case today from Newegg.com, hopefully the rest will be here on Wed. I am already overwhelmed with all the wires in the case. My first question is about the 2 120mm fans I have in the case. They have a four pin and 2 pin wire coming from them the wierd thing ( at least to me ) is the four pin has a male end and also a female end split off of it. Am I correct in guessing I can string the 2 fans together like X-mas lights? Hook one up to the power source then the other one to the other end?
Second question, I have read mechBgon mention several times about worms infecting a system when upgrading windows to service pak 2. I use a hub on a cable connection ( I imagine many of you are cringing ). What is the easiest way to protect my computer during this vulnerable time? i was thinking of buying a firewall at Best Buy.
Third concern, I am fairly confidant I can get it all put together and running but the bios set up intimidates me. If the MoBo's manual is lacking in how to information is there a good site or a guide on bios set up?
Any input is greatly appreciated (remember I have already bought the components so don't rag on me if I made a bad choice I agonized over it for days on what to buy). Sorry for the poor grammar and spelling mistakes.
Azbec
Epox Nforce3 MoBo
AMD 64 3200+
WD 74g 10k Raptor
MS XP home
Azbec
