Building Modulating circuit
cableguy44
28
Need some help. I have thought of a project for myself. I would like some input. I am going to try to make a circuit that can take my cd player output and modulate it on a frequency in the FM band so that I can listen to it in my work truck that doesnt have a tape deck. So here is what I came up with that I will need:
1 oscillator at desired output frequency
1 modulator, is FM mixer the same thing????
1 amp circuit
1 filter circuit
Any suggestions or any ideas on the schematic, I would appreciate it before I get started. My main question is, is an fm mixer basically just a modulator.
IamElectro
1,470
It would be cheaper to buy one in the long run. If you look around you can find one powered off the cigarette lighter for 20-30 bucks.
Building one is possible but a simple unit will not broacast in stereo.
harrkev
659
If you use a regular mixer, you will get an AM transmitter. The usual method of creating FM is to use a PLL circuit. You can add your desired signal to the error signal (after error goes through a low-pass filter). Then, you run the output of the PLL oscillator through a suitable RF amp to an antenna.
This is not a job for a beginner.
