Building Intel socket 370 system: Celeron 1.4GHz or PIII 1.2GHz
ahsia
1,031
I know the PIII will be about $40-$50 more, do you all think it is worth it? Thanks!
ElFenix
102,393
8,552
no, that celeron is the same thing as the p3, with a slower bus speed.
dexvx
3,899
Not overclocking, the P3-S would whoops down on it. Overclocking to 133FSB, the celeron would fair quite nicely, but would still be behind the P3-S.
Barnaby W. Füi
12,343
It will be about twice the price, and definitely nowhere near twice the performance, so personally I wouldn't.
DaveSimmons
40,730
670
What are you doing with it?
For DVD / divx playback (not recording) on a home theater PC even a celeron 1.0A is fine. For recording TV you probably should get a 2+ GHz P4 celeron.
spanky
25,716
4
Originally posted by: MercenaryForHire
Stick with the Tually Celeron. The P3-S will cost you an arm, a leg, and your left nut. :confused:
- M4H
arm + leg + left nut = $50?! :Q
ahsia
1,031
It'll be for a server. But not going to be doing much processing.... probably a file server most likely....
DaveSimmons
40,730
670
then a celeron 1.3 - 1.4 will work great. Memory usually makes the difference, a celeron 1.3 with 512 MB will make a better fileserver than a p3-s with 256 MB.
