Hiya,
Ok so I finally got the computer up and running and started encountering corrupt file issues. Since I have one basic goal with this computer (gaming) I figured well ok I'll test the HD's with the western digital utility. All tests report no erros or problems...
I then zero out the HD's and reinstall windows xp
Go through updating all drivers and reinstalling hardware support software etc.
I get it all running smooth. Posting fine, Bios configured, nary a single issue to be found anywhere.
Then I started getting Internet explorer erros - this application has encountered blah blah we are sorry for the blah blah it must now close...
Fine. Be that way. So I zero out everything over again and start from scratch.
This time I get it running smooth again. drivers, software, etc all up and running. BUT I did not upgrade to SP2 and I ran minimal windows updates .net 1 was added
All is fine..
Last thing I did tonight was to install Norton Internet Security 2004 - the installation requires you to restart your computer. OK
Restart, hang, freeze, manual shut down.
Restart - now the computer won't post..
restart after CMOS reset.... computer won't post
removed battery reset CMOS again.. no joy..
Am now ready to throw this pile of freaking money out the damn window, run down out into the street and kick it around for an hour just for fun.
AMD 64 fx53
(2) western digital raptors 74Gb 10k rpm
Pioneer DVD
MSi K8N Neo2
Ati x800 XT
Antec 550 true control
(2) Corsair CMX512-3200XLPro 400Mhz 2-2-2-5
yes i have tested with other memory and move memory around. reseated all components. the system was running fine one minute and literally stopped in less than 45 seconds after afore mentioned crapola.
All is fine..
AMD 64 fx53
Pioneer DVD
MSi K8N Neo2
Ati x800 XT
