yellowperil
All the system-building guides I've looked at online are a bit dated. Anyone know of any that will guide me build step-by-step without improvising? Here's what I'll be using:
EPoX EP-8K7A
Athlon T-bird 1GHz 266FSB OEM
Enlight 7237/300W case/PS
Installing the mobo looks pretty straightforward, but I had some questions about the CPU/heatsink/thermal compound. Here are my questions:
1. How do I install the CPU?
2. Do I install the CPU before or after installing the mobo?
3. How do I install the heatsink/fan? What is a good HS/fan choice?
4. What thermal compound should I use, if any? (not planning to OC, yet)
5. How do I apply the compound? Is there a pad I need to take off?
6. Does the EPoX board have jumper settings I need to set before turning it on? Does it come with a comprehensive manual? (EPoX site doesn't have one up)
If there is a guide out there detailing these questions I'd appreciate it. The rest of the stuff I've installed in the past, but this is the first time putting everything together myself. Thx
EPoX EP-8K7A
