- Jun 2, 2001
- 311
- 0
- 0
Well, I'm about to get started on building my first system tonight. I'll be going to pick up my motherboard and processor after work (CUSL2-C BP & P3 1 GHz... I know, I know, Intel
Anyway, before I start getting myself into trouble, I thought I'd seek the advice from the experts here on a few things.
First, my specs:
- Antec SX-840
- CUSL2-C Black Pearl + P3 1 GHz
- 256MB PC133 Crucial RAM (x2)
- Maxtor DM+60 40GB (x2)
- Plextor 16x CD-RW
- Toshiba 16x DVD
- Hercules Game Theater XP
- ATI Radeon 64MB DDR
- USR 56k Modem
- Netgear FA311 TX 10/100 NIC
1. Is it easier to install all of the drives (DVD, CD-RW, 2 HDs, floppy) into the case before installing the motherboard or after?
2. My case comes with two rear exhaust fans, and room for two front intakes. I won't be overclocking and will be using the stock HSF with thermal pad. Should I install one or two front fans? (I'd like to keep noise to a minimum but also wanna make sure my system gets adequate cooling.)
3. Is there a performance difference between having the 4 IDE devices on their own channel as opposed to using a master/slave setup on 2 channels? I'm wondering if I should pick-up an ATA100 PCI card and whether it would have an effect on performance.
4. Should I dual boot Win98/2k or just run Win2k? I will be using this computer primarily for web development (Macromedia and Adobe stuff), general Internet (email, chat, etc) tasks, and some gaming (mostly strat/sims and shooters). I'm wondering if I still need Win98 for anything.
Thanks in advance for the help!
First, my specs:
- Antec SX-840
- Plextor 16x CD-RW
- Toshiba 16x DVD
- USR 56k Modem
