Building first PC next week, and need a little help.
Rick974
I'm finally taking the plunge, and building a system from scratch. 🙂
I got a couple of questions first though.
I plan on buying the Asus P4TE motherboard and P4 processor from Fry's Outpost.
Fry's Outpost
Has anybody used these guys before, and are they good?
Also, when I get the processor, will the heat sink and fan already be attached to the processor?
And if not, will I need to put some grease between the heat sink and processor?
Thanks for any help, and wish me luck. 😀
<< Has anybody used these guys before, and are they good? >>
Heard of them, they're good.
<< Also, when I get the processor, will the heat sink and fan already be attached to the processor? >>
Nope. But I wouldn't worry. Attaching the P4's HSF is very easy and risk free.
<< And if not, will I need to put some grease between the heat sink and processor? >>
Nah, only if you plan on ocing.
I'd suggest you go to Anandtech tomorrow AM, they should have a review of the new 850e chipset along with 533fsb P4's and you will want to change your specs accordingly.
