Building first-ever rig
bramma
36
Well, I've recently moved out of my parents house and I am now trying to build myself a computer. I've been using different sites so far, and this is what I have came up with. Keep in mind that this computer will be used mainly for mmorpg games like everquest. I also don't have anything to carry over from another computer, so I will need a monitor and an operating system, and I am trying to do it all for under $800 dollars. Well, this is what I have so far...
Case: Antec solution series Super mid tower case with 350W Smartpower power supply 'SLK3700AMB) $69
CPU: AMD Athlon Xp 2500 333 fsb, 512K Cache processor $80
Motherboard: Epox 8rda3+ $96
Ram:Kingston ValueRAM 184 PIN 256 MB DDR PC-2700 $48
Sound: Built into motherboard. Figure I can get a cheap set of speakrs for $15 to $20 bucks.
Video Card: Powercolor ATI Radeon 9600 PRO Video card, 128 MB DDR, 128 bit, DVI/TV-Out, 8x AGP, model R96A-C3N" $124
Hard Drive:Samsung 80 GB 7200 RPM hard erive, oem $68
Also, I may need a case fan or two for cooling, because I'm not sure if this case comes with enough to keep the system cool.
Optical drives: Lite-On 52x32x52x CD-RW drive, model LTR-52327S $33
Floppy Drive: OEM drive from newegg $10
Keyboard: Saw a nice cordless at walmart for $30
Monitor: Samsung 753DF-T/T 17" Dynaflat crt monitor $169
Operating system: at a loss for this one. Was looking for a lost-cost solution for windows xp. But retail, it is about $150
Extra IDE Cable for hard drive: $5 at dealsonic.com
Antistatic wrist strap: $7 at dealsonic.com
Right now, this comes to about $900. I really need to squeeze it in under $800. So, any help and suggestions are greatly appreciated. Also, let me know if all of these components are compatible.
sisooktom
262
You might just want to save up a little longer rather than cut components. It's gonna be hard to build a gaming rig for that money, considering you need everything right down to the keyboard and mouse. Because you're really a little light on both memory and graphics and you're already over budget. Maybe someone here can come up with a setup that you can overclock and squeeze you in.
paladiin
181
Few suggestions:
Mobo: The Epox board you've chosen is a bit pricey for an nForce2 board in my opinion. Unless you specifically need a feature on that board that's not on another (I'm not aware of one) you can save $25-$30 by going with a different board. I've heard good things from the DFI NFII-Ultra board and of course there's the Abit N7F, Asus A7N8X, or even cheaper Epox boards. $100 for a budget mobo is just too expensive in my opinion.
CPU: Go mobile Barton. Even if you never use it's "unlocked" potential, the lower voltage required will give you lower temps, which is always a good thing. $8 more for the mobile 2500+, or save $3 and get the mobile 2400+. But let's be honest - you'll want to overclock it, even just a little bit!
Hard Drive: Keep your eyes on the Hot Deals forum for a good "after rebate" deal on a hard drive. It's usually the only part I buy from a retail chain store simply because you can get a great deal after rebate. The last big one was $39 after rebate for a 120GB 7200RPM 8MB cache drive.
OS: Yes, XP is what you want. Home is perfectly fine for most users. No need to buy a Retail version - OEM's work just fine (some rules apply to purchasing OEM version). Or if you have a previous version of Windows around, just buy the Upgrade version. Expect to pay around $90.
Monitor: Take a peek on the Hot Deals board - there was a KDS 19" CRT for $79 after MIR you might be interested in.
and now the bad news...
RAM: First off, since you mentioned it, EQ is a major RAM hog. I went to 1GB specifically for EQ, and am glad I did. 256MB simply is not enough in my opinion to make EQ happy. 512MB minimum, 1GB recommended. Next, I highly suggest going PC3200 over PC2700. While it costs a little more, it will give you headroom if you decide you want to really use your nForce2 400 and your mobile barton's potential (ie 200Mhz FSB).
dennisjai215
Banned
Apr 16, 2004
1,261
use a regular ABIT NF7 NOT the NF7-S one + a AMD Mobile 2400, its what i use cheap and good.. i bought it for like 160+ a month or 2 ago but im sure u can get it cheaper now
it'll run cool enough that you do not need a case fan unless you overclock...
and i've seen 9600pros for around 110.. cheaper than that 124$ one at newegg
but you may want 512mb stick of ram instead of 256.. so save a little here and there and add the ram
edit: the newegg has mushkin value ram pc3200 512mb for 83 bucks.. that is better than getting a stick of 256pc2700 @ 48 bucks
