I will be ordering my parts from newegg either next week or the week after, they are as follows
Case Centurion 534
http://www.newegg.com/Product/Product.asp?item=N82E16811119106
Processor AMD AM2 3500+ http://www.newegg.com/Product/Product.asp?item=N82E16819103633
RAM Crucial 1gig (2x512mb) ddr2 667
http://www.newegg.com/Product/Product.asp?Item=N82E16820146568
Mobo: DFI Ultra-II M2
http://www.newegg.com/Product/Product.asp?item=N82E16813136015
Vid Card: Evga 7600 GT KO
http://www.newegg.com/Product/Product.asp?item=N82E16814130017
HD: WD 7.2k 80g SATA
http://www.newegg.com/Product/Product.asp?item=N82E16822135106
Monitor: Hanns-G HW-191DB 19 inch 5 ms widescreen
http://www.newegg.com/Product/Product.asp?item=N82E16824254005
Wireless Adapter: Linksys WMP54G
http://www.newegg.com/Product/Product.asp?item=N82E16833124115
Optical Drive: Samsung Combo drive
http://www.newegg.com/Product/Product.asp?item=N82E16827151086
Speakers: Logitech X-230
http://www.newegg.com/Product/Product.asp?item=N82E16836121123
Mouse: Leftover logitech mx310
Keyboard: Microsoft keyboard
http://www.newegg.com/Product/Product.asp?item=N82E16823109164
Thermal Grease: AS5
http://www.newegg.com/Product/Product.asp?item=N82E16835100007
OS: Windows XP Home
http://www.newegg.com/Product/Product.asp?item=N82E16832116056
1.I still need a recommendation on a psu, I will be overclocking everything. I would like to spend $50-$70
2. Are all of these components compatible?
3. Do DFI boards work with Crucial Memory?
4. I am purchasing a antistatic wristband from the local radioshack, can you explain in detail how i should have the wristband connected to what and such so that i am at no risk of ESD.
Thanky.
Edit: Oh, and if it matters, i will be using this for gaming (Source games mostly) and generaul usage things. And budget is $1000, can go a little over if necessary.
Case Centurion 534
Thermal Grease: AS5
OS: Windows XP Home
Thanky.
