Hi :
This is the CPU forum, so I hope it's the right place to ask this question. I just joined, and this is my first message.
I'm building my first computer, and have got almost all the components set to go. But I can't exactly figure out how to put the CPU into the motherboard.
It's an AMD Athlon XP 3200+ CPU, and an Asus A7N8X-E Deluxe motherboard.
I lifted up the lever on the side of the ZIF socket, then lined up the triangle at the corner of the CPU with the corner of the ZIF socket where the lever arm is attached. Then, I carefully placed the CPU in the ZIF socket, and it seemed to go in ok, nice and flat. Next, I tried to lower the lever arm to lock the CPU in place, but the arm only goes a little way before it binds up.
I am reluctant to push hard on it, since I really really really don't want to ruin either the CPU or the motherboard. It seems to be stuck very bad, and I don't know what's going on. After trying this a couple of times, I removed the CPU and it looks ok. I turned the CPU over, and carefully sighted along all the little pins on its underside, but none of them appear to be bent.
Does anybody here have any ideas what might be going on? Once the CPU is set into place in the ZIF socket, does the lever arm have to be pushed real hard to made it go down? Is that normal?
If anyone has successfully gotten this kind of CPU to fit into an Asus motherboard, I would appreciate your advice on what to do next.
Thanks in advance for any assistance you can give.
Dave
Dave
