notanotheracct
so i'm about to start building 2 HD "cages". i've got a roll of aluminum, cutting tools, bending tools to make angles, vinyl grommets to possibly use to reduce vibration, and alot of hope 😀
one cage is going to be for a tivo DVR unit and my intent is to make a cage that holds two drives, one above the other, and have a fan either blow air to or away from them. there is already one fan toward the back of the unit blowing air out, so my problem is where to place the second fan. it can be in one of three positions:
1. against the FRONT of the unit, blowing air over the HDs toward the rear fan
2. at the SIDE of the unit, air can blow against the HDs where it'll end up hitting the ribbon cable
3. between the HDs and the back fan
the problems with positions 1 & 2 is that fans intake is against the case, which i'm not sure not much of a negative that might be (i'm no expert of fan/airflow). position 3 seems fine to me but i'd rather have air blow over the HDs if possible, and two fans blowing in opposite directs - i'm not sure how smart that is.
and regarding the cage itself, i'm not sure if i should make it out of aluminum strips on the HD sides to screw into, or if i should make it more like a solid 'U' shape, or of i should make it like a square wind tunnel.
thoughts? opinions?
and i apologize in advance for bad descriptions/artwork... don't send the art police after me 🙁
thoughts? opinions?
