RyanGreener
Hi everyone, I'm building a desktop for my dad and I'm not sure which components to go for. It is a desktop that will be built for Pro/Engineer and AutoCAD. The recommended requirements of Pro/Engineer tell me nothing, because they are vague with the requirements, such as:
2.4 GHZ CPU - Is this dual core, single core, and not to mention clockspeed doesn't tell everything.
1 GB RAM and 2 GB of Hard Drive Space (Pagefile/Swap I believe?) - I don't want to rely on using the hard drive, so I'd rather have more RAM.
And they also did not give any required GPUs. So what i'm asking here is, if any of you have had experience using pro/engineer, what is a good setup that will allow it to run flawlessly. I'm trying to spend the least possible, so keep budget in mind. I basically only need the following information:
What CPU to use?
What GPU to use?
How much RAM?
What CPU to use?
What GPU to use?
How much RAM?
