building custom computer, do i have all the parts?
Wheatmaster
I already a cd-rw drive, graphics card, mouse, hard drive usb ethernet for internet and i'm ordering the rest from Newegg:
Accessories - Apparel
**This item is NOT REFUNDABLE, exchange for same exact item only!!**
NewEgg.com Black Tee Shirt - Size: Large
Black T-Shirt with Silver Print Featuring "Newegg" Text and Logo. See Image for details.
These shirts are 100% cotton. They come is S, M, L, XL
Limited Time Offer: Free with ANY Maxtor, MSI, ATI, or Seagate Purchase !
How does it work: Buy any qualified item and add this T-Shirt to cart. Credit Given at Order Confirmation. Limit One Per Customer more info>
N82E16800999118 $10.00
$10.00
Newegg.com Black Baseball style hat with Stitched Newegg Logo
Nissun Adjustable Hat with metal clip,
Black hat with Silver/White Stitching,
Limited Time Offer: Free with ANY Motherboard, CD/DVD Burners, or Video Card Product!
How does it work: Buy any qualified item and add this Baseball Cap to cart. Credit Given at Order Confirmation. Limit One Per Customer more info>
N82E16800999226 $10.00
$10.00
Cases (Computer Cases, ATX Form)
ANTEC SOLUTION SERIES MODEL SLK1600 (BEIGE) w/ANTEC SMART POWER 300W P4/AMD POWER SUPPLY ATX12V - RETAIL
Offering a large 8-drive capacity in a convenient mini tower. This new Mini Tower is a cost-effective solution with the features and quality you expect from Antec.
Specifications:
Driver Bays: External 3 X 5.25" - 2 X 3.5" - Internal 3 X 3.5" (Quick Release Drive cage for 3.5" Drive bays)
System Board: Standard ATX
Expansion Slot: 7 Slots
USB/IO: 2 X USB (front)
Case Dimensions: 16.75" (L) X 8.25" (W) X 16.75" (H) more info>
N82E16811129121 $49.00
$49.00
Floppy Drives
MITSUMI D359M3 FDD 1.44MB 3.5INCH - OEM
Specifications:
Connector: 34-pin Floppy cable Standard Connector.
Modes: HD(1.44MB) Supports: Dos, Windows 3.1, 95/98 NT3.51 and 4.0
2DD(720kb) Supports: Dos, Windows 3.1, 95/98 NT3.51 and 4.0 more info>
N82E16821103104 $6.50
$6.50
Keyboards
Logitech Black Internet Keyboard - OEM more info>
N82E16823126123 $17.00
$17.00
Memory (System Memory)
KINGSTON KVR133X64C3/512 VALUERAM 512MB PC133 - OEM
168Pins SDRAM 64X64 Chip RAM 7ns Speed Clock 3 Speed Lifetime Warranty --* Works With PC & Mac * -[PowerMac G4 Models 350-1GHz*, G4 Cube, eMac. (G4 PCI 'Yikes' models NOT compatible)] Works with many PC-based desktops with a 133MHz (PC133) memory bus speed. more info>
N82E16820153101 $64.00
$64.00
Motherboards - AMD
MSI Motherboard for Socket A Processor Model# K7T TURBO2 (6330-250) KT133A - RETAIL
Manufacture Support# ContactP/N# 626-581-3001.
Supports: Socket A, AMD Athlon/Athlon XP (Palomino) up to 1800+, Thunderbird up to 1.4GHz, Duron 950MHz
Chipset: KT133A/VT82C686B
Memory: 3x 168-pin unbuffered DIMM sockets. Max 1.5GB SDRAM
FSB: 100/200& 133/266 MHz .
IDE: Ultra DMA 66/100, . ATX Form Factor,
Slots: 5x PCI, 1x CNR, 1x AGP 4x, AC 97,
Ports: 4x USB (2 front, 2 rear)
Audio: AC 97 Warning P4 Voltage connector. may be required, See picture more info>
N82E16813130035 $45.00
$45.00
Processors
►On Sale!
AMD Athlon XP 2000+/266 FSB Processor CPU - Retail 2000+/ 1.67GHz, AXDA2000BOX
The AMD Athlon XP processor with QuantiSpeed architecture powers the next generation in computing platforms, delivering extra performance for cutting-edge applications and an extra-ordinary computing experience.world's highest overall performing PC processor.
Specifications:
CPU: 1.67 GHz
Type: 2000 XP
Cache: 256K
Core: Thoroughbred
BUS: 266MHz
Socket A (PGA)
Retail box (Heatsink and Fan Included)
more info>
N82E16819103383 $66.00
$66.00
Speakers
Logitech Z-340 3 Piece Speaker System
Innovative subwoofer delivers twice the bass energy of similar subwoofers
Stylish satellites stand on desk or mount on wall
Convenient headphone jack and volume control
Dual chamber subwoofer plays louder and goes lower for unbelievable bass
Satellite speakers provide smooth mid and high frequencies
Internal power supply eliminates bulky wall adapters
Total power output: 33 watts RMS
Satellite speaker power output: 6.5 watts RMS per channel
Subwoofer power output: 20 watts RMS
System frequency response: 35 Hz-20 kHz
Mfg Part# 970058-0403 more info>
Standard Warranty only
Am i missing anything?
Sound card?
Break your list down into 1 line items, not the whole description. I'm dumb like that. 😕
Like
(Mobo)
(CPU)
etc
etc
etc
i'm sticking with pc133 cause the uses for this computer is just typing and internet. Moderator can you put this post in the right forums thanks.
That motherboard is almost as nice as an ECS. So, if you want a nice wall decoration, sure, its fine.
I would suggest you look at that motherboard and cpu combo. The specs for the motherboard say it only supports an Athlon 1800+ CPU, and you have in the list that you are going to order a 2000+. I do not believe this will work.
Also, where are your hard drives and optical drives? (Cd-rw and cd-rom)?
Personally I would get the following if I was on a budget:
Shuttle AN35N Nforce2 motherboard
You can then pick a stick of PC2700 or better DDR Ram. If they get the money in the future they can enable dual channel ddr after installing another stick of memory. Just my 2 cents.
Check the MSI site to make it will handle the Thoroughbred 2000+ you plan to use.
Like several others, imho it is a waste of money to go PC133 memory and mobo.
ddr components are available for about the same money, so why sdr?
sounds nearly complete; some additions that are good to have on the bench while assembling.
round cables - alot less clutter and improves air flow
additional jumpers - always drop 'em when you need 'em
thumb screws for case and mother board
anti-static wristlet
drive mounted usb and firewire ports - nice to have 'em in the drive bays, if the case doesn't already have 'em in front
thermal grease - should come with processor and fan, but make certain
surge protector
mouse and pad
cheese for the mouse
extra power cord splitters - they're cheap and will save you alot of time if you need one during construction
extra cooling fan - antec usually has pre-mounted fan cages that will improve cooling, just add fan
ps - you kind'a went overboard on the info; do you work for newegg????
surge protector
mouse and pad
no i just copy and pasted the info. I already have the hard drive and cd drive. I can't go over the $450 limit with the monitor.
ok this is my final order
$10.00
$10.00
Foxconn Super Case Model# PC-132 w/350W Power Supply -with USB ports Retail
Specifications:
Material:Steel
Form Factor:ATX Micro ATX
Bays:7 Full Size
Expansion Slots:4x 5.25", 3x 3.5" and 4 3.5" Internal
Fans:0 Included
Power Supply: 350W Power Supply
Dimensions: DxWxH 18.75x7.25x16" more info>
N82E16811154018 $25.00
$25.00
Floppy Drives
Specifications:
$6.50
Keyboards
$17.00
$64.00
Monitors - CRT
Samsung Series SyncMaster 753DF-T/T 17" CRT monitor - Retail
16" Viewable
0.20mm dot pitch.
Max resolution:1280 x 1024 @ 65Hz
Connection: 15-pin d-Sub (analog)
3 year limited manufacturer warranty more info>
Standard Warranty only N82E16824001120 $129.00
$129.00
Motherboards - AMD
$45.00
Processors
►On Sale!
Specifications:
CPU: 1.67 GHz
Type: 2000 XP
Cache: 256K
Core: Thoroughbred
BUS: 266MHz
Socket A (PGA)
more info>
$66.00
Speakers
Standard Warranty only N82E16836121102 $45.00
$45.00
Extend my Standard Warranty on the above qualified items: $14.61
Subtotal » $417.50
Shipping and Handling Charge »
Tax Instruction for All Resellers How Newegg.com calculates shipping $
APO/FPO - Military ONLY FedEx Standard Overnight FedEx 2Day FedEx Express Saver Choose which State to ship AA AP AE ALASKA ALABAMA ARKANSAS ARIZONA CALIFORNIA COLORADO CONNECTICUT DISTRICT OF COLUMBIA DELAWARE FLORIDA GEORGIA HAWAII IOWA IDAHO ILLINOIS INDIANA KANSAS KENTUCKY LOUISIANA MASSACHUSETTS MARYLAND MAINE MICHIGAN MINNESOTA MISSOURI MISSISSIPPI MONTANA NORTH CAROLINA NORTH DAKOTA NEBRASKA NEW HAMPSHIRE NEW JERSEY NEW MEXICO NEVADA NEW YORK OHIO OKLAHOMA OREGON PENNSYLVANIA PUERTO RICO RHODE ISLAND SOUTH CAROLINA SOUTH DAKOTA TENNESSEE TEXAS UTAH VIRGINIA VERMONT WASHINGTON WISCONSIN WEST VIRGINIA WYOMING
Grand Total » $ 417.50
Like i said i already got a hard drive, usb ethernet for internet, cd-rw drive, graphics card, mouse and plenty of round cables. Anything else?
Well, you seem determined to go sdr, don't know why.
MSI mobo with 266a chipset is only $4 more, 512mb Samsung ddr 2100 memory $3 more.
Go to the MSI website and there's a bios update that will let that motherboard support up to I believe a 2800+ or was it 2600+.
Everything should work after you put it together.
Like the other posters, I don't see the point in using PC133.
Especially since there's hardly any price difference, there's no reason to go for crappier stuff when it's the same price for better....even if it's just for internet and general usage.
Shuttle Motherboard for AMD processors, Model AK38N KT333 Retail
Chipset:VIA KT333CF+VT8235
FSB:200/266/333 MHz
RAM:3 x 184-pin DIMM DDR333/266/200 up to 3GB
IDE:ATA133/100/66 up to 4 Devices
Slots:1x AGP(4x) and 5xPCI slots
Ports:2xPS2,2xUSB,1xCOM,1xLPT, and audio ports
Onboard ALC650 6 Channel Audio More... Model#: AK38N
Price: $51.00
GEIL 512MB PC-2700 (333MHz) DDR RAM
6 Layer Ultra Low Noise Shielded PCB, 32x8 Low Density/Unbuffered,
Model# GE5122700V
Type: 184-pin DDR Memory
CAS 2.5 6-3-3 2T
Lifetime Warranty Model#: GE5122700
Price: $68.00
So replacing the motherboard and memory for better stuff would cost $10.
Within your limit of $450.
