- Mar 31, 2010
- 101
- 16
- 81
Hello, I'm looking to upgrade my CPU, motherboard and memory. Budget is around $700. I've settled on the i7-10700 CPU at $280. So that just leaves the motherboard and memory. Maybe $200 on 32GB of DDR4 3000 or faster memory. Then probably ~$150 on a 560 series motherboard. Afraid I don't know much about memory and motherboards, which is why I'm asking for help.
1. What YOUR PC will be used for. 1080p video editing & FPS gaming (Battlefield titles, MMOs)
2. What YOUR budget is. ~$700
3. What country YOU will be buying YOUR parts from. US
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from. N/A
5. IF YOU have a brand preference. None
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
GPU: EVGA RTX 2060 XC Black Gaming
SSD: Samsung 850 EVO M.2, Mushkin 1TB SATA III, WD Blue 2TB SATA III
PSU: Corsair RM750x 750w 80+ Gold
Case: Fractal Design Define R5 Silent ATX (2015)
HSF: Noctua NH-D15S (running two fans)
Case fans are Noctua NF-A15 x 4, Fractal Design GP-14 x 2
7. IF YOU plan on overclocking or run the system at default speeds.
Will OC memory & GPU; CPU will run at stock speed
8. What resolution, not monitor size, will you be using? 1080p
9. WHEN do you plan to build it? This month
10. Do you need to purchase any software to go with the system? No software
