Building an OC system for a Q9550
Caveman
2,537
34
System will be air before transitioning to Water Cooling where I hope to get 4+ GHz
Vid card will be 280 GTX. I'll probably try 2X SLI at some future date...
Looking to get ASUS PQ5 or Gigabyte board...
Any recommendations?
DSF
4,902
A P5Q isn't going to be able to run SLi. If you're serious about that you'll need an Nvidia chipset board.
That said, I'd personally skip the SLi.
OCGuy
27,224
37
780i "FTW" edition if you want an SLI board.
Otherwise, the ASUS will be fine.
Caveman
2,537
34
Okay,
How about memory... There's a give away price for Corsair 1066 RAM right now... but it's 2 x 1GB.
System will have 4 GB of RAM
Is using 4 sticks of 1 GB RAM slower than 2 sticks at 2GB/ea?
OCGuy
27,224
37
Okay,
It is harder on your Northbridge. I think the general consensus is that 2X2 GB would be alot easier on your system.
OCNewbie
7,596
24
Get the Gigabyte GA-EP45-UD3P. Seems to be THE choice for OC'ng quads, especially the Q9550.
Do a google search for that combo and check out xtremesystems.org? and overclockers.net (something like that). They have 30+ page threads devoted to that motherboard OC'ng quads and that mobo in general.
zerogear
5,611
9
nVidia Chipset as above said, but honestly, I find NVIDIA chipsets to be kinda crappy & unstable for OC.
TidusZ
1,765
I second the UD3P / UD3R (Go for the R since your not using ati cards), the Asus gets lots of recommendations but then you buy it and try to overclock and max out at like 460 fsb, whereas the UD3R will go well over 500. There really is no choice.
