mrSHEiK124
I am not asking for hardware advice, I already got the covered, well, I kinda am, but its about the video capturing part
OK, thisi really a pretty confusing situation for meh, so let me explain to you my needs:
1. Replacing an FTA sat box we use for recieving Arabic channels, I've decided on the WinTV-Nexus-S
2. Replacing a VCR and a DVD player
3. Video capture from our TWC HDTV box (not in HDTV duh, most likely going to use the S-Video output on the box)
4. Video capture from our Dish Network box, again, most likely using the S-Video port or the second Composite port
5. Hardware MPEG2 Encoding is important
6. Outputting in Component (DVI is a nogo, our tv doesn't have it) to our HDTV
now i can't seem to figure out exactly how I am going to do this, if it were just one source i needed to capture from, I'd get a WinTV PVR 250 or something and get it over with
Also, if i went with BeyondTV or Sage or any of those progs AT recently reviewed, would it allow me to say, watch the FTA stream and record the Cable or DN stream? thats why the hardware MPEG2 encoding is important to me, because the most intesive hardware i'll be using is a Sempron 3100+, and Athlon XP 2500+, and if i am lucky, an Athlon 64 2800+
and as far as the YPbPr output goes i am pretty sure that i am limited to ATI's 9xxx Radeons, their AIW 96-98xx cards, and the nVidia GFFX 5700 Personal Cinema
