I'm thinking of getting a wardrobe closet like this one: http://www.ikea.com/webapp/wcs/stores/s...uctId=11536&langId=-1&parentCats=15597*15852*15856 and putting my three or four systems inside it to deaden their noise. I would have to cut holes for cables and ventilation, of course, and also line the closet with sound-deadening material.
Do you think this is a viable idea? I want this cabinet as a lasting solution to the noise problem I've been plagued with for years. I want this to be a big box that I can put systems inside of and largely eliminate their noise, instead of spending money to silence each computer system individually (I have tried that, and it only goes so far, especially with someone that has sensitive ears like myself and with regards to hard drive noise).
I need some advice on:
1. how to remove hot air from the closet without letting out too much sound. Individual fan holes for each shelf or make a duct and send hot air from each shelf to the top?
2. what to line the closet with (foam, dynamat, etc) -- preferably something budget-conscious.
3. what tools I will need ( jig saw?)
Any feedback is very much appreciated, Thanks.
