I just put together a pc with a refurbished asus CUSL2, my old celeron 400 (which will be upgraded to my celeron 1ghz once I do the bios update if needed), and an old stick of 128 mb ram.
i'm using the onboard video but have also tried a separate card.
The green indicator/LED on the motherboard comes on when I plug in the power and hit the on switch on the psu.
Nothing happens after that. The fan on the cpu spins okay. the HD turns on. However, there's no speaker beeps etc. Monitor remains off.
the cpu was working when it was last used. I had upgraded so it went to storage. Same with the ram.
I am using an antec 300W smartpower psu. It has a 12V connector which isn't being used on this board. Is this psu okay to use with this board? One time I forgot to plug in the 12V 4-pin connector on a pc and nothing happened until I plugged it in. Is this the problem here?
