Nerfmeplease
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
General everyday use and hopefully gaming
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
600 US Dollars
3. What country YOU will be buying YOUR parts from.
USA there is a microcenter near me
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
nope
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
nope
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
nope
7. IF YOU plan on overclocking or run the system at default speeds.
Not overclocking
8. What resolution, not monitor size, will you be using?
1080p monitor
9. WHEN do you plan to build it?
Hopefully today
http://pcpartpicker.com/p/18CSh here is my build what do you think
600 US Dollars
nope
nope
nope
Not overclocking
1080p monitor
Hopefully today
