i already selected the parts for my budget gaming computer. However i would like you to check and see if they are good and compatible. here it is:
Case 99.99
Specifications:
Case Type: Mid-Tower Case
Color: Black
Material: All Aluminium Alloy
Drive Bays: 5.25" x 4/0, 3.5" x 2/4 (external/internal)
Expansion Slots: 7
Front Ports: 2xUSB2.0, 2xAudio, IEEE 1394
Power Supply: N/A
Cooling System: 2 x 80mm front, 1 x 80mm top, 1 x 80mm rear
Motherboard Compatibility: ATX; 12" x 9.6" (30.5cm x 24.5 cm)
Dimensions: 19.6" x 7.2" x 17.8" (LxWxH)
http://www.newegg.com/app/View...=11-119-035&depa=1
CPU ? 225.00
Specifications:
Model: Athlon 64 3200+
Core: Winchester
Operating Frequency: 2.0GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/ 512KB
Voltage: 1.5V
Process: 90nm
Socket: Socket 939
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Warranty: 3-year MFG
Packaging: Retail(with Heatsink and Fan)
http://www.newegg.com/app/View...=19-103-502&depa=1
Motherboard - 137.00
Specifications:
Supported CPU: AMD Athlon 64/Athlon 64 FX
Chipset: K8T800Pro + VT8237
RAM: 4x DIMM Dual Channel DDR400/333/266 Max 4GB
Slots: 1x AGP 8X, 5x PCI
Ports: 2x PS/2,1x COM,1x LPT,8x USB2.0(Rear 4),1x IEEE1394,1x RJ45,2x S/PDIF out,Audio Ports
IDE: 2x ATA 133 up to 4 Devices, 1x ATA 133 up to 2 Devices by Promise 20378 with RAID 0/1/0+1
SATA: 2x Serial ATA with RAID 0/1, 2x Serial ATA by Promise 20378 with RAID 0/1/0+1
Onboard Audio: Realtek ALC850 8-CH
Onboard LAN: Marvell 88E8001 GbE
Onboard IEEE1394: 2x 1394 ports
Form Factor: ATX
http://www.newegg.com/app/View...=13-131-510&depa=0
RAM ? 248.00
Specifications:
Manufacturer: CORSAIR
Speed: DDR400(PC3200)
Type: 184-Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2-2-2-5
Support Voltage: 2.75V
Bandwidth: 3.2GB/s
Organization: two 64M x 64-Bit
Special Features: Plug-n-FragTM Auto-Configuration - Boots automatically using the Xtra-Low latency values of 2-2-2-5
Warranty: Lifetime
http://www.newegg.com/app/View...=20-145-523&depa=1
Power Supply ? 89.50
Specifications:
Type: ATX
Maximum Power: 480W
PFC: No
Power Good Signal: 100-500ms
Hold-up Time: >=17ms at Full Load
Efficiency: >=68%
Over Voltage Protection: +5V trip point<+6.5V;+3.3V trip point<+4.1V;+12V trip point<+14.4V
Overload Protection: Latching Protection+5V @<47A;+3.3V @ <48A;+12V @ <18A
Input Voltage: 115 VAC / 230VAC
Input Frequency Range: 47-63 Hz
Input Current: 9.0A for 115VAC;5.0A for 230VAC
Output: +3.3V@30A;+5V@38A;-5V@0.5A;+12V@22A;-12V@1.0A;+5VSB@2A
MTBF: 80,000 hrs. @ 25ºC
Approvals: UL, TUV, CB, VDE, FCC CLASS B, DEMKO, NEMKO, SEMKO, FIM
http://www.newegg.com/app/View...=17-103-909&depa=0
Video Card ? 249.99
Specifications:
· AGP 8X (compatible with 4X and 2X AGP 2.0 compliant slots)
· Superscalar GPU architecture
· High speed GDDR3 memory interface
· NVIDIA® CineFX? 3.0 engine
· Microsoft® DirectX ® 9.0 Shader Model 3.0
· NVIDIA® UltraShadow? II technology
· 64-bit floating texture filtering and blending
http://www.chumbo.com/Info.aspx?id=239864
Hard Drive ? 66.00
Specifications:
Capacity: 80GB
Average Seek Time: 8.5 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: Serial ATA
Features: 3D Defense System
Manufacturer Warranty: 5 year
Packaging: OEM, Requires additional Power adapter
http://www.newegg.com/app/view...=22-148-019&depa=0
dvd-rom ? 63.99
Specifications:
Write Speed:16X DVD+R, 4X DVD+RW, 8X DVD-R, 4X DVD-RW, 48X CD-R, 24X CD-RW and Double Layer 2.4X DVD+R
Read Speed: 48X CD-ROM/CD-R, 16X DVD-ROM
Interface: ATAPI / E-IDE
Buffer: 2 MB
Random access time: 110 ms (CD-ROM), 105 ms (DVD-ROM)
Features: Buffer Underrun Proof technology
Packaging: OEM Bundle with out software (see pictures for details) http://www.newegg.com/app/view...=27-131-241&DEPA=1
1178.48
Case 99.99
Specifications:
Color: Black
Expansion Slots: 7
Power Supply: N/A
CPU ? 225.00
Specifications:
Core: Winchester
Voltage: 1.5V
Process: 90nm
Socket: Socket 939
Specifications:
Form Factor: ATX
RAM ? 248.00
Specifications:
Bandwidth: 3.2GB/s
Warranty: Lifetime
Specifications:
Type: ATX
Maximum Power: 480W
PFC: No
Efficiency: >=68%
Video Card ? 249.99
Specifications:
Hard Drive ? 66.00
Specifications:
Capacity: 80GB
Buffer: 8MB
dvd-rom ? 63.99
Specifications:
Buffer: 2 MB
1178.48
