As I've stated your resolution doesn't need a 560 Ti. A 6850/6870 will play anything on your resolution perfectly fine. I play with an overclocked 560 Ti on 1920x1080 and have no framerate issues on high settings. 1080p is 60% more pixels to be filled, while 560 Ti is only about 30-40% faster than a 6850 and 10-20% faster than 6870. Don't waste your cash bro
BUT I HATE RADEON CARDS(tho i have never ever used one,but i love nvidia so much
You should get a cheap gpu and save for a nice monitor. Hell get a used monitor if you have to.
I agree mfenn, but then again it really depends on what the computer is being used for and how often it's being used. For example when I played counter-strike professionally we ALL used giant CRT monitors and ran the lowest res possible, 640x480. Nothing fancy was needed because that was the "best" way of doing it![]()
Should not combo 2500K with a H61 motherboard. It's a CPU with an unlocked multiplier, but the motherboard can't overclock. Get the i5-2500 or i5-2400 if you don't overclock. Also you don't need an aftermarket cooler. Or perhaps you intended to OC and didn't know H61 can't do that? If so, swap to a Z68 board like Asrock Z68 Pro3.
What are you planning to do about the monitor? If you keep it, you're overspending on the GPU as stated a couple of times previously. Your resolution doesn't need a 560 Ti.
While Corsair GS600 is a good unit, you don't need that much power if you don't OC. Corsair CX500 V2 would be fine.
With the above savings you can easily afford 2x4GB DDR3.
