RandomUser
I've been upgrading my current system piecemeal for several years and decided to bite the bullet and build a new system from scratch now that the Core2 Duo processors have been released.
I plan to get the E6400 and hopefully overclock it with all the great info from here.
I don't play to go SLI (will get a 7900GT for now), though a friend said I should consider getting an SLI board anyway in case I change my mind.
Here's my current list of components:
Case: Thermaltake Armor Series VA8000BWS Black Aluminum/Steel ATX Full Tower Computer Case
http://www.newegg.com/product/product.asp?item=N82E16811133154
PS: Antec Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply
http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
CPU: Intel Core 2 Duo E6400 Conroe
http://www.newegg.com/product/product.asp?item=N82E16819115004
Memory: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800
http://www.newegg.com/Product/Product.asp?Item=N82E16820145034
MB: ASUS P5B Socket T (LGA 775) Intel P965 Express
http://www.newegg.com/product/product.asp?item=N82E16813131030
Video: MSI NX7900GT-VT2D256E-HD Geforce 7900GT 256MB 256-bit GDDR3 VIVO PCI Express x16 Video Card
http://www.newegg.com/product/product.asp?item=N82E16814127218
HD: 2*Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM 16MB Cache SATA
http://www.newegg.com/product/product.asp?item=N82E16822148144
Monitor: SCEPTRE X20G-Naga III Black 20.1" 8ms Widescreen HD Ready LCD Monitor
http://www.newegg.com/product/product.asp?item=N82E16824112176
CPU Fan: ZALMAN CNPS9500
http://www.newegg.com/Product/Product.asp?Item=N82E16835118003
I've gotten Antec cases in the past, but they don't seem to have any full-sized tower cases anymore. I was looking at the P180 but the Thermaltake has a lot more room and comes with more fans.
Is 550W enough for this system? Or should I get a larger one?
Should I get a better motherboard if I am wanting to overclock significantly?
I thought about getting a Raptor drive for my system files; how much of a performance difference will I notice?
I'm open to any and all suggestions.
