Hello,
I'm looking to build a new personal rig for development, photoshop and occasional gaming and would like some advice on what parts I should use.
Here's the details:
1. What YOUR PC will be used for:
Programming/Development/Photoshop/Occasional gaming
2. What YOUR budget is:
£1000
3. What country YOU will be buying YOUR parts from:
UK
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc:
Nope
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are:
EVGA GeForce GTX460 SCC
21" Monitor (new)
DVD/CD RW Drive
7. IF YOU plan on overclocking or run the system at default speeds:
Undecided, looking for advice on this part (see below)
8. What resolution will you be using?
1600x1200 (current monitor)
9. WHEN do you plan to build it?
Within 1-2 Months
I have currently started looking at parts and this is what i'm thinking so far, an advice would be greatly appreciated.
Motherboard: Asus Sabertooth Z77, Gen3, Intel Z77 Chipset - £148.77
CPU: Intel Core i7 3770K Quad Core @ 3.5GHz - £251.94
CPU Cooler: Corsair Hydro H60 - £52 or CoolIT ECOII
RAM: Corsair Vengeance LP, DDR3, 1600Mhz - £62.16
SSD : OCZ Technology 128GB Vertex 4 - £88.94
HDD WD 500GB Caviar Blue - £52
PSU: 650W Corsair Enthusiast Series Modular - £64.65
Case: Fractal Design Define R4 - £89.91
I'm thinking of overclocking to 4.4GHz at a later date. Will the H60 be sufficient for that amount of overclocking to the i7? Or will I need a bigger cooler?
Thanks
Here's the details:
£1000
UK
Nope
21" Monitor (new)
DVD/CD RW Drive
Within 1-2 Months
Thanks
