Hi,
I am planning to buy a new Haswell i5-4690k based PC and I am looking for Motherboard advice.
I am not a gamer, the PC will mostly be used for browsing, development (Eclipse, MS Visual Studio. etc). I am not even buying a dedicated GPU as I plan to use the CPU one. So that part is not too important to me (even if I buy a graphics card in the future it will be a mainstream one, not the SLI /Crossfire or whatever the hardcore gaming stuff are called).
I want a z97 based board as I plan to overclock the CPU (a modest one, 4Ghz or so).
I know you would say that I don't need an overclocked 4690 for my type of work but I am currently working on a 6 year old Core Q8300 and I desperately need an upgarde, plus the board + CPU is not that expensive anyway and I want to get the max speed for that amount of money.
I had a look at some budget Z97 boards and found the following:
1. ASRock Z97 Anniversary
2. Asus Z97-P
3. GigaByte GA-Z97M-DS3H / GigaByte GA-Z97M-D3H / GigaByte GA-Z97-HD3
4. MSI Z97M-G43 / MSI Z97-G43
5. ASRock Z97 Pro3 / ASRock Z97M Pro4
Which one would you recommend? Please feel free to suggest another one in their price range.
Thx
2. Asus Z97-P
Thx
