this is only the second computer ive built, Im hoping Im ready to purchase the parts and put it together but I was hoping someone could be generous enough to read the system info (below) and answer my questions, and in general, just check it over, give me their thoughts, any problems they see, etc. What concerns me most is the power supply and the motherboard/chipset/processor being complete and able to support the additional items. The board is compatible with the AGP card, I've checked that (1.5 V) and the board is SATA compatible Im pretty sure, but I couldnt get info on the number of connectors for the power supply and the type of connectors needed for DVD drive, HD, and AGP card. Is that becuase its standard and not necessary to check for compatibility as everything is compatible with everything in that field? Is the power supply too much at 550W? Thanks to anyone for answer my questions!!
Intel 875P chipset on Intel Desktop Board D875PBZ (from http://www.axiontech.com/prdt.php?src=PG&item=36101) (comes with chipset right?)
With Audigy2 Platinum THX 6.1 sound
And ATI Radeon 9800 Pro AGP card
With Power supply: http://www.antec-inc.com/pro_details_powerSupply.php?ProdID=20550
And a DVD+_RW drive yet to be determined
Monitor with standard VGA connector
Creative Inspire 6.1 6700 Speaker System
Barrucuda 7200.7 SATA 160GB (Serial, ATA/150, 7200 RPM)
few questions:
1. when you buy an intel motherboard, it comes with a chipset preinstalled, correct?
2. will power supply be compatible for AGP card, motherboard, and hard drive. I?m not familiar with power connectors, etc. will I have to purchase correct ones, will it come with only certain ones that have to match the devices, how do I know there will be enough connectors of the right type?
3. will 550 be enough for the system (AGP card is 330A)?
few questions:
