- Oct 14, 2005
- 92
- 0
- 0
building a internet box but ran into a wall
I was going just fine, installed/updated windows, drivers, softwares etc... almost done, only thing left was to connect case front USB/Audio cables to the motherboard
I had to play around a bit cause case cables and motherboard manual didn't match, turning computer on and off when ever I need to check and change connectors
then all the sudden computer doesn't boot
it powers up, fans, drives running but nothing shows up on screen
did not do anything to fry up the board
tried CMOS reseting
bare booting out side the box
thought maybe onboard video so tried sticking in video card, still....
nothing helps
ECS GEFORCE6100SM-M2
X2 3800+
OCZ 2x 1gb gold
250gb sata drive
dvd burner
no fans except AMD stock cooler
because I'm using micro box I had to get 350w matx psu, but should be enough to power above right?
tried CMOS reseting
nothing helps
X2 3800+
OCZ 2x 1gb gold
250gb sata drive
dvd burner
