- Sep 21, 2003
- 13
- 0
- 0
This is my first posting.... My budget is around $500-600 and I would like to build a new comp. I was wondering if anyone can help me put it together. The only thing Im looking to get is : video card, motherboard & cpu combo, and DDR RAM.
Any recommendation? such as what kind/brand to get on each... try to keep in mind that $500-600 is the budget.
This is solely for game playing ie. HL2, Command & Conquer Generals, etc....
I was thinking of either the 9500/9600/9700 pro or non pro... with a CPU w/ 800 mhz FSB, and 1 gb or ram. Does having the right motherboard makes any difference? Can you give me specifics such as the namebrand/models of the followings configurations that you guys came up with? (ie. Powercolor 9600 Pro 256mb , Sapphire 9500 pro 128mb, etc.)... I think i might be willing to trade CPU power for more GPU power... but I would like to hear your guy's 2 cents to help me make my final decison. I use the www.pricewatch.com to seach and compare my prices so if you guys could recommend some links to cheaper places... please by all means help... I dont want to blow all my money on a comp that i might need to upgrade yet again soon.
