i'm pretty much decided on using an ammo can. basically a cross between the "ammo lan" and the "ammo box" projects you can see at www.mini-itx.com. anyway, i'm wondering what kinda Power supply specs would be necessary to run the 5000 (533 mhz CPU) mini-itx mobo, and a 20-40 gig 7200 RPM hard drive? would it behoove me to bump down to 5400 RPM for less power consumption?
anyway, i'm gonna be using either an audigy or a hercules fortissimo sound card, and run line level inputs directly to an amp.
i'm still not sure how i'm gonna do volume control or listen to radio (news/weather)
i'm almost set on using an LCD attached to the cieling of the car, that will flip down, as a display. almost. not ENTIRELY sure...
