mfenn
If I had 3000 bucks I'd probably spend them on a PC. :biggrin:
Anyway,what I meant is,no matter if what you get is good enough,it won't be enough a little while after you get it.That's why I wanted the 4770K,because I wouldn't need to upgrade soon.Initially I wanted AMD's FX8350.The GPU is very easy to upgrade (If we don't factor in the money needed),unlike the CPU and mobo.
That's just the thing though. Barring a huge change in game development (1% probability, parallel programming is hard), there is never be a case where the hyperthreading on the i7 makes a difference between playable and unplayable.
