- Apr 17, 2004
- 17,555
- 1
- 0
Here's the ideal specs, which will most definitely change as technical limitations are discovered:
2-3 mile range
Small device that attaches to a cat's collar
Reports location back to receiver which interfaces with PC
Has to be able to record cat's movement for 24 hours
The software on the PC will show the cat's current location relative to the receiver, with distance and ideally +/- Z as well.
We're having trouble finding the hardware to do this. Found a neat little transeiver made by Aerocomm that's 1" x 1" and has like 20mW power consumption. Range isn't great but that's not critical.
I'm particularly concerned about the receiver. HTF are we gonna get the data from the cat's transmitter thru a receiver into a PC program? We aren't going as far as writing our own device drivers & ******, only as far as a program to map the data coming in.
Any thoughts, suggestions, comments, concerns, or farewell wishes?
2-3 mile range
