Building a deck...concrete posts into ground or set conrete footers?
Oct 19, 2000
17,860
4
I have a deck build coming up in the next couple of weeks, and I've seen just as many sites suggest setting posts into the ground with concrete as sites that suggest pouring concrete footers and attaching my posts with brackets.
Without laying any plans on paper yet, I'm anticipating upwards of 20 posts, either 4x4 or 4x6. At the tallest end of the deck, it will be around 50"-55" off ground level. At the smallest end, around 24"-36". Entire size of the deck will probably be around 10'x20', but that's still up in the air.
So which is it ATOT? I'm more comfortable with setting posts 24"-30" into the ground with concrete around them, but I want to make this deck whichever way is best to do it.
iGas
6,240
both method works, and you don't need to set the post so deep unless you are worries about hurricane & such.
iGas
6,240
Originally posted by: wedi42
set the posts on brackets. it keeps them dry.
That work well too, and the posts would last longer than the deck.
meltdown75
37,548
7
i dug 22 holes with a hand auger, set my 4x4s, and filled each hole with concrete. 4 feet deep
i'm not sure which method is best but i built my deck in 2003 and it is holding up well! good luck
Goosemaster
48,775
posts: gravel at the bottom for a few inches, set the post in place with concrete -very easy to do.
pier: a solid subterrainian concrete pier will allow for universal post compatibility IF you need it if you change your mind since you can use brackets to customize it. you also don't have to worry about deck material health.
Kelemvor
16,928
8
be sure to go below the frost line if you live somewhere you have to deal with that.
Also call your city hall as many places have codes about that and you can be made to rip out the deck if you do it wrong.
CPA
30,322
4
I did about 30, set post bracket on concrete, then nailed joists to bracket. Not sure which is best either, but I will say in hindsight there is a section of my deck where I wish I had set 8' 4x4s for the railings. I did the railings an alternative way and I haven't been happy with them.
Oct 19, 2000
17,860
4
Gravel at the bottom for drainage is why I'm estimating 24"-30" hole depth.
Nov 5, 2001
18,366
aside from any local code requirements, it depends on if you live in a cold climate. if you live somewhere that it freezes, you need footings extending below the frost line otherwise the deck will heave in the winter.
meltdown75
37,548
7
i'm strongly considering modifying the lower part of my deck. there's just too many spindles, i'm not a fan of how it looks anymore. not to mention my veggie garden is to the left of the lower level of my deck, which is enclosed by 4' spindles. the stairs to my yard are to the right.. i don't really like walking all the way around my deck to water my garden or pick tomatoes :/
in hindsight it was a nice deck, but way too big and ended up not being practical given the current location of my garden.
Greenman
21,699
6,137
The answer is; it depends.
If you happen to live where someone cares, setting the posts in concrete and attaching it to your house creates an earth wood contact situation. This is often of no importance what so ever, but if you sell and there is a termite report, it will be called a section one item and could cost you fair pile of nickles to correct. If you do plant the posts in concrete, be sure to use pressure treated material and hangers rated for PT contact. The PT will eat zinc plated hangers in a year or so, you don't want that.
Oct 19, 2000
17,860
4
Forgot to mention that this deck is free-standing and will not be attached to the house. I live in central KY, so it does freeze, but I don't think the frost line is ever more than a few inches down.
Squisher
21,204
66
How to best set the posts depends on your location and the type of soil.
I notice your profile says Kentucky, so not much frost heaving.
I'd ask some locals.
vonmises
36
Our deck is was just done with footings, 4 feet down with a bracket bolted to the concrete and nailed to the post. Our supports are only 2 feet though. The frame was done 15 years ago and is still holding strong. We just added a new section and redid the flooring/railings. Edit: I typed before that last post.
Nov 5, 2001
18,366
for comparison, the rost line in Kansas is 36 inches. In Minnesota it can be over 5 feet.
for a 10'x20' deck with posts along the perimeter, using 2x8 joists you should do 3 rows of posts each way.
Sea Moose
6,933
7
this ia what we did at my mates house, his reaoning was that termites dont eat the steel. But do eat the underground timber
alkemyst
83,769
19
Being that the OP is talking concrete posts this would work.
Many make the mistake of setting wood posts in the stuff and this is not only against code (at least around here), but causes many problems.
paperfist
6,539
286
www.the-teh.com
What problems? The wood is going to rot either way.
The argument is that once it's set in the concrete there's not much air getting in to move the rot process ahead. Plus with the gravel at the base there's drainage away from the soil.
The concrete will rot against the wood because of dissimilar materials? The same can be said with the brackets.
I've used both processes. I would never use the bracket process again. When you set the bracket in concrete you get what 2 - 3" of the anchor going into the concrete? You have to be sure the concrete is completely surrounding the anchor part of the bracket. The brackets typically don't end up being too sturdy and can become loose.
If it were me I'd go overkill and use 6x6 and go below the frost line even if it's not there. It'll be sturdy with 3'+ of concrete around your post and surrounded by earth. It's going to take eons to rot with a 6" post of wood.
skyking
22,622
5,730
I agree, and I've seen so many rotted off posts set in concrete. people underestimate how fast that goes.
I used pier blocks with adjustable saddles on the interior of my porch, and poured saddles into a footing pads around the exterior.
Other than the skirting I maintained 6" between earth and wood. The skirting wood contacts 8x16 pavers set with a slope in gravel.
EDIT:
Link to elevated post base.
That keeps the wood away from the dirt and eliminates wet rot.
I set up a piece of lumber and screw the base to it to keep them in line and approximately on grade.
There is no need to be exact on the grade however. just top the posts using a water level, laser, or a long level.
pour each base in an 8" deep by 2' by 2' pad and it will be as strong as you need.
