Building a cheap system
dwdty9
535
I'm trying to build a system for video editing/audio editing, etc for real cheap. I do not need a case but I do need a monitor as well. My budget is no more than $700, though I might go the route of Dell to get the monitor, since I can use my credit account...maybe.
So I decided against going with a prebuilt system because I wanted to customize things to my liking. I can get all these parts for $485 including shipping at newegg. What do you think?
NEC 16X DVD±R $37.99
WD1600JS 160GB 7200 RPM SATA 3.0Gb/s $65.99
COOLMAX CP-500T EPS12V 500W Active PFC Power Supply $54.99
CORSAIR ValueSelect 1GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Unbuffered $76.00
Gigabyte GA-8I945GMF Socket T (LGA 775) Intel 945G Micro ATX Intel Motherboard $98.50
Intel Pentium D 805 Smithfield 533MHz FSB LGA 775 Dual Core,EM64T Processor Model BX80551PE2666FN - Retail $129.50
dBTelos
1,858
You may want to look at Asus, DFI, epox, or MSI for a mobo. Everything else looks good.
thecoolnessrune
9,673
583
A Intel 920, Seasonic 430 PSU, XP-90 and Delta EFB series fan for it would be my replacements. The main reason is the PSU. COOLMAX is one of the budget overrated brands. Plus its an EPS power supply. Most likely not even compatible with your system.
thecoolnessrune
9,673
583
Also, I would recommend the ASUS P5LD2-VM DH over the Gigabyte mobo. It has integrated video so you wont have to worry about a graphics card. If your just doing video editing, you dont need a video card anyways.
dwdty9
535
movie maker? ok, i'm not that amateur!! thanks for some advice though. What is EPS power supply mean?
EDIT: I see it now. Not compatable, so that means switching to a different PSU
