- Oct 16, 2016
- 14
- 0
- 66
PLEASE when you POST threads asking for input on system builds tell us
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Streaming videos, netflix etc... light gaming, some fps gaming. At 1080p resolution
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
<500
3. What country YOU will be buying YOUR parts from.
USA
4. IF you're buying parts OUTSIDE the US...
NA
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No pref. Best for the money...
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Yes, Asrock 970m pro3
Gtx 950
Sandisk 480GB SSD
FX6100
Crucial Ballistix Sport XT 16GB Kit 8GB x2 DDR3 1866 MHz PC3-1490
Atx case
Decent power supply (will support latest cpu/video card.
CM Hyper 212Evo cooler.
7. IF YOU plan on overclocking or run the system at default speeds.
Default right now overclock down the road
8. What resolution, not monitor size, will you be using?
1080p
9. WHEN do you plan to build it?
Within 2 weeks
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Have retail windows 10, no extra software needed.
I want to upgrade, i was thinking cpu/mb
Maybe a better case. I dont need any 5.25 bays. Only 2.5 for ssd. Im not having any issues with my current hardware just time to upgrade. Plan to get into some PC gaming. Just want the biggest bang for the buck under 500. I want to upgrade whatever makes the most sense right now. I would like to use my ddr3 if i can, if not its fine I'll gonwith ddr4. The parts left over from this will go toward a htpc/web gameing build for living room. In a couple months.
Sent from my SAMSUNG-SM-G935A
<500
USA
NA
Gtx 950
Sandisk 480GB SSD
FX6100
Atx case
1080p
Within 2 weeks
