cluster550
I've been having problems with one of my computers for quite some time now. I've tried reformatting the hard drive and reinstalling windows and things, but it keeps crashing very frequently. I finally got the time and decided to start swapping out parts to see if I could locate the problem. When I opened my case, I noticed that there was a light brown/orange build-up(rust?) on about a dozen of the capacitors on my MSI K7N420 Pro. Everything else in the case looks fine. The system is air cooled, so there has been no leaking or condensation to cause rusting if that is what the build-up is. I was wondering if this build-up could be causing the instability and if I should try scraping it off. Thanks for any help.
