It's been about 15 years since I've build a computer, so I would really appreciate it if someone would casually review my build to see if I made any critical errors or if I'm completely missing the boat. Any comments or suggestions / recommendations is greatly appreciated. Thank you.
1. What YOUR PC will be used for.
Bioinformatics (Python, SQL, Excel). Photo editing (Illustrator, Photoshop). Various scientific software. No games.
2. What YOUR budget is.
~$1500
3. What country YOU will be buying YOUR parts from.
United States
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
N/A
5. IF YOU have a brand preference.
No brand preference
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
No recycling of parts.
7. IF YOU plan on overclocking or run the system at default speeds.
Default speeds. Overclocking not an option.
8. What resolution, not monitor size, will you be using?
Never thought about it. Whatever is standard.
9. WHEN do you plan to build it?
August. Waiting for the Amazon sale (and crossing my fingers) before I purchase parts.
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Windows.
My current build plan:
PCPartPicker part list: http://pcpartpicker.com/p/stdxqs
CPU: Intel Xeon E5-1620 V3 3.5GHz Quad-Core Processor ($286.99 @ SuperBiiz)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste ($6.79 @ OutletPC)
Motherboard: ASRock X99E-ITX/ac Mini ITX LGA2011-3 Narrow Motherboard ($257.86 @ Newegg)
Memory: Crucial 16GB (2 x 8GB) Registered DDR4-2133 Memory ($172.99 @ SuperBiiz)
Storage: Samsung SM951 NvME 256GB M.2-2280 Solid State Drive (~$220 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.49 @ OutletPC)
Video Card: Sapphire Radeon R9 280 3GB Dual-X Video Card ($149.99 @ Newegg)
Case: Fractal Design Node 304 Mini ITX Tower Case ($84.99 @ NCIX US)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($78.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 OEM (~$110)
Total: $1450.55
Prices include shipping, taxes, and discounts when available
I'm waiting to purchase the NvME version of the SM951 when it comes out later this month.
I will be purchasing Windows 10 when it comes out later this month.
The motherboard comes with the Dynatron R24 60mm CPU cooler.
Thank you!
~$1500
United States
N/A
No brand preference
Windows.
Total: $1450.55
Thank you!
