Hi Everyone,
My EVGA nforce 780i SLI Motherboard (A1 Version, NVIDIA nForce 780i SLI, Socket 775, ATX, Audio, PCI Express 2.0, Dual Gigabit LAN, S/PDIF, USB 2.0, Firewire, Serial ATA, RAID) recently burnt out, and I can't seem to find the same model online at Newegg or TigerDirect. I was wondering, since that part seems to be discontinued, are there any other comparable motherboards that offer about the same, or even slightly improved, performance? I'll list my other components below for compatibility concerns. Also, I'm more than willing to replace my DDR2 RAM with DDR3 RAM parts, which will likely alter the suggestions you may give.
GPU: PNY GeForce GTX 280 Video Card - 1GB GDDR3, PCI Express 2.0, SLI Ready, (Dual Link) Dual DVI, HDTV, VGA Support
CPU: Intel Core 2 Quad Q6600 Processor HH80562PH0568M - 2.40GHz, 8MB Cache, 1066MHz FSB, Kentsfield, Quad-Core, OEM, Socket 775, Processor
RAM: DDR2 800
Thanks in advance, any help is greatly appreciated.
RAM: DDR2 800
