Hi I am planning to build my first Gaming PC for around $700 - $750 and am looking for advice on whether this build will work well, especially will this build (esp. the graphics card) have enough power to work or is it wasting too much power
The Build (all parts from newegg.com)
Seagate Barracuda LP ST31000520AS 1TB 5900 RPM 32MB Cache SATA 3.0Gb/s 3.5" Hard Drive - OEM $79.99
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 22X DVD±R DVD Burner - OEM $30.99
Rosewill R5601-BK 0.8mm Japanese Cold Rolled Steel Screw-less Dual 120mm Fans ATX Mid Tower Computer Case - Retail $49.99
ASUS M4A78 Plus AM3/AM2+/AM2 AMD 770 ATX AMD Motherboard - Retail $79.99
XFX HD-487A-ZWFC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail $144.99
OCZ StealthXStream OCZ700SXS 700W ATX12V / EPS12V SLI Ready CrossFire Ready Active PFC Power Supply - Retail $79.99
AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core Black Edition Processor Model HDZ940XCGIBOX - Retail $169.99
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2P10664GK - Retail $71.99
I am pretty much basing this build on the Phenom II processor and the 4870 video card. The rest are just the ones with the best rating on newegg.
any and all help is appreciated
Vrman
Vrman
