Sorry for the length of this article, wasn't sure what was important and what wasn't tried to include everything.
Building a new computer,
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner ? OEM
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C5 - Retail
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard ? Retail
XFX HD-487A-ZHFC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card ? Retail
Antec Three Hundred Black Steel ATX Mid Tower Computer Case ? Retail
PC Power & Cooling S75QB 750W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply compatible with core i7 - Retail
Creative Sound Blaster X-Fi XtremeGamer 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - Retail
Western Digital Caviar SE WD2500AAJS 250GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
Hook everything up, things go okay. Had some problems because the things are kind of tight in the case (especially the video card ? barely fits), and the power supply is on the bottom of the case while all the motherboard power connectors are at the top of the case.
Hook the HD and the DVD drive up to the SATA connectors. The motherboard actually has two sets of SATA connectors ? 6 orange ones that are part of the ICH10R southbridge, and 2 purple ones that are listed as part of a GIGABYTE SATA2 chip. Not sure what the differences are and why both are on the motherboard. Anyhow, I hooked up to the southbridge SATA ports (SATA2_0, SATA2_1).
Powered the machine up, and everything looked normal. Brought the machine down, attached a PS2 keyboard and mouse, powered back up and got into the BIOS. The standard CMOS page had my drives listed: The HD as the Channel 0 master and the DVD as the Channel 1 master. Both Channels 0 and 1 had master and slave listed, while Channels 1 and 2 just had master listed, weird but it accounts for all 6 connectors.
Set the time and the date. Since I had a sound card, I disabled the onboard sound. Set the boot order to CD ROM then Hard Drive. I pretty much left the other settings alone. Saved the CMOS settings and rebooted. Popped in the Win7 RC disk I had burned and proceeded to install Windows 7. A little bit into installation, a dialoged popped asking me to insert the disk with the CD/DVD drivers. Did some research into this, and it looked like this was going to be a long, involved solution. Didn?t have time for that, so I just took out the Win7 installation disk, and rebooted with the Win XP SP2 installation disk I had.
The Win XP installation disk correctly identified my HD and gave me the option to create a partition on it. I selected the HD and told it to format the drive with the NTFS file system. About 1.5 hours later (after formatting completes), the installation disk copies a bunch of files to the HD, then tells me that the machine will be rebooted, take any disks out of the drives, and installation will continue after the reboot.
This is things start to get funky. During the boot process I see a message ?Discovering disk drives; None; no disk drives found?. The machine won?t boot from the HD, I get a ?disk read error occurred: press CTL+ALT+DEL to restart? error message. This happens two or three times in a row. I bring the BIOS back up and the HD is still listed in there. I change some settings (SATA controller to ACHI rather than IDE, stuff like that) and reboot. Same error. I disconnect from the southbridge SATA connectos and connect to the GIGABYTE SATA2 (purple) connectors. The boot up screen changes a little and it actually lists my drives (the DVD is the master and the HD is the slave, if it matters). However, same end result ?Disk read error occurred: press CTL+ALT+DEL to restart?
I go into the bios and switch the GIGABYTE SATA2 controller to ACHI mode, reboot. Now it lists my drives (and in color!) during the boot process, but still gets the disk read error.
I figure that maybe there is something wrong with the HD so I boot from the WD HD diagnostics disk I have. The diagnostics immediately error out: ?No drive found. Error Code 0120? (could be wrong on the number)
I put the XP install disk back in and decide to go through installation again. Installation starts up, shows the HD but it says there is nothing on the HD and I have to go through formatting it again. Format the partition again with NTFS, 1.5 hours later it copies files over the formatted drive and then reboots the system. This time instead of the disk read error it just goes into and endless reboot loop. Figuring maybe an unformatted HD would be an issue with the WD diagnostics, I reboot from the HD Diagnostics disk. Same error ? ?No Drive Found?
Stuck and grasping for straws.
Choir
Choir
